Oldtimers forumas
Dabar yra 2021 Bir 13 Sek, 22:27
Naujos temos kūrimas Atsakyti į temą  [ 28 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3
Autorius Žinutė
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 25 Tre, 17:06
Atsijungęs
Užsiregistravo: 2005 Kov 06 Sek, 16:17
Pranešimai: 570
laurynas400 rašė:
Nu gerai ponai mieli antra nuotrauka atsirado: nuvaziavom paziurejom pas drauga garaze ir nusprendem, jog tai
Bentley 3.7 Litre Park Ward (1934)
Valio, kitos masinos negali buti...
Arba...
Taip, tai Bentley 3 1/2 Park Ward 1933-1936 #B108 AH :bravo:
Atsiprašau, bet patingėjau iš anglų versti...
Years in production : 1933 - 1936
No. made : 1,177
Engine : 6 cylinder in-line configuration.
Bore & Stroke : 3 1/4" x 4 1/2"
c.c. : 3,669
Transmission : Single dry-plate type clutch, 4 speeds and reverse, synchromesh
on 3rd and 4th gear
Chassis : Pressed-steel parallel girder with channel and tubular crossmembers,
downswept between axles to achieve low centre of gravity, semi-elliptic springs front
and rear.
Dimensions : Wheelbase 126"
Performance : Max. speed 92.2 mph (148.4 km/h)
In 1933 the 3 1/2 Litre Bentley was launched. The place and date for the premiere were cleverly chosen.
In August 1933, during the Ascot Race week the sports car made its debut.
The first cars were delivered to eagerly awaiting customers in October 1933.
This newcomer was a clever combination of the completely new chassis from the
Peregrine project and the proven engine from the 20/25.
Learning by experience that when using a supercharger neither smoothness nor longevity
could hope to match Rolls-Royce's standards, the board of directors stopped any further
developments in this direction. Instead the engine of the
20/25 was adopted. Using a crossflow cylinder head, re-profiled camshaft and employment of two carburettors,assisted by an increase in compression, the six cylinder's output was raised to some
120 bhp. The power figure of the basic
engine did not exceed more than about 80 hp.
The 3 1/2 Litre Bentley met with general acclaim, because it fulfilled the wish for
a powerful motor car of exceptional fine handling. Many of the first bodies were built as cabriolets,
but before long, closed versions in the form of sports salooons and coupes also became accepted
as suitable attire for the 3 1/2 Litre. These were manufactured mainly by Park Ward
o dėl pirmos turiu pasakyti, kad tėra žinoma, jog tai irgi Bentley 3 1/2, tačiau kokia modifikacija ir aš nesugebėjau surasti, nors turiu indentifikacinį numerį #B132 CR, beje labai įdomus modelis ir pilnai tikiu, kad buvo specialiai sukurtas tik va kam :?: :?: :?:
P.S. dar vienas įdomus dalykas, kad ant daugelio Bentley ratų kalpokiuko yra įspausta raidė "B", o ant šio modelio pilnas žodis "BENTLEY"
dėkui visiems spėliojusiems :-)
Dalintis: Dalintis Facebook
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 26 Ket, 10:29
Atsijungęs
Užsiregistravo: 2004 Geg 31 Pir, 20:39
Pranešimai: 4206
ryce rašė:
laurynas400 rašė:
Arba...
No. made : 1,177
c.c. : 3,669
on 3rd and 4th gear
and rear.
idek nuotrauka
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 26 Ket, 10:32
Atsijungęs
Pranešimai: 4206
laurynas400 rašė:
WANDERER rašė:
ryce rašė:
Negi per sunki mįslė :?: Kur gi Wanderer :?:
Faktas kad tai anglas,kebulas ne gamyklinis,bet spec.kebulu atelje darbas,na o marke arba BENTLEY arba ALVIS,isleidimo metai 1937-39mm
Tai as siulau varianta del atelje: ZWAKMAN motors, iseivis is Lietuvos :shock:
bar neturiu knygos po ranka apie spec kebulu firmas ,bet panasu kad kebulas ERDMANN & ROSSI firmos
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 26 Ket, 11:13
Atsijungęs
Pranešimai: 570
WANDERER rašė:
laurynas400 rašė:
WANDERER rašė:
ryce rašė:
Tu čia kalbi apie pirmą nuotrauką kurios nesugebėjom tiksliai indentifikuoti :?: o pagal šį numerį #B132 CR tavo knygose negalima atrasti :?:
:!: Jeigu moderatoriai leistų galėčiau įdėti normalaus dydžio nuotrauką
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 26 Ket, 11:48
Atsijungęs
Pranešimai: 4206
ryce rašė:
WANDERER rašė:
laurynas400 rašė:
WANDERER rašė:
ryce rašė:
Taip kalba eina apie auto is pirmos nuotraukos.Na greitu laiku as prie tos knygos neprieisiu,nes paskolinau vienam pazistamam o sis isvaziaves.Kur radai indentifikacini numeri?Dokumentus turi sio BENTLEY ar antroj pusej nuotraukos uzrasyta?
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2005 Geg 26 Ket, 23:22
Atsijungęs
Pranešimai: 570
WANDERER rašė:
ryce rašė:
WANDERER rašė:
laurynas400 rašė:
WANDERER rašė:
ryce rašė:
Taip, numeris užrašytas ant nuotraukos
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2009 Geg 26 Ant, 15:46
Atsijungęs
Užsiregistravo: 2007 Lie 24 Ant, 13:31
Pranešimai: 3172
Labai sudomino pirma nuotrauka.. Koks pirmo automobilio kėbulas vis dar nėra aišku?
_________________
allcarindex.com - 11.000+ markių, 4600+ koncepcinių modelių. - Didžiausias automobilių žinynas internete! Sukurta Lietuvoje!!
facebook.com/allcarindex
Į viršų
 Aprašymas
Atsakyti cituojant
 Pranešimo tema:
StandartinėParašytas: 2009 Geg 30 Šeš, 22:52
Atsijungęs
Pranešimai: 3172
Gerb. kolegos, profesionalai, identifikavo Bentley pirmoje nuotraukoje kaip 1934-ųjų Thrupp-Maberly Airline-Saloon!
_________________
Į viršų
 Aprašymas
Atsakyti cituojant
Dabar prisijungę
Ieškoti:
Pereiti į:
1, 2, 3, 4, 5, 6
 Paskutinės sukurtos temos
Naujų pranešimų nėra Tema turi prikabintų failų Fon #20 Motociklas
Fon » 2020 Gru 26 Šeš, 10:45
Naujų pranešimų nėra Tema turi prikabintų failų #3 laimisas Atsakyta: Ikarus 55 (autobusas)
laimisas » 2020 Lap 17 Ant, 16:59
Naujų pranešimų nėra Tema turi prikabintų failų Atsakyta_Fon #19 motociklas
Fon » 2020 Bal 17 Pen, 7:25
Naujų pranešimų nėra Tema turi prikabintų failų Fon #18 motociklas
Fon » 2020 Bal 17 Pen, 7:22
Naujų pranešimų nėra Tema turi prikabintų failų #4 Rudge Atsakyta AWO 700, SIMSON EMW 700 (motociklas)
Rudge » 2020 Bal 09 Ket, 15:45
Naujų pranešimų nėra Tema turi prikabintų failų #17 motociklas_atsakyta, Panther M75
Fon » 2020 Bal 11 Šeš, 22:18
Naujų pranešimų nėra Tema turi prikabintų failų # 2 dalius-nsu Motociklas+++Atsakyta++Ardie RBU 505 ++
dalius-nsu » 2020 Bal 11 Šeš, 17:08
1, 2, 3, 4, 5, 6
 Paskutinės aktyvios temos
forume Auto/moto mįslės
2021 Sau 04 Pir, 15:16
Naujų pranešimų nėra Tema turi prikabintų failų #35 Chevrolet KB/DAF
2020 Lap 21 Šeš, 1:21
Be vėjo Peržiūrėti naujausius pranešimus
2020 Lap 20 Pen, 9:49
laimisas Peržiūrėti naujausius pranešimus
Naujų pranešimų nėra Tema turi prikabintų failų #28 Be vėjo
2020 Spa 30 Pen, 20:33
Naujų pranešimų nėra Tema turi prikabintų failų #33 Atsakyta Daihatsu spider, Vignale 1963
2020 Geg 21 Ket, 14:04
2020 Geg 20 Tre, 19:13
Naujų pranešimų nėra Tema turi prikabintų failų #31 Be vėjo
2020 Geg 20 Tre, 10:15
Oldtimers administracija
Į viršų
