E85 kuras
paulius858
Pranešimai: 2
Užsiregistravo: 06 Geg 2013, 17:15
E85 kuras
Standartinė paulius858 »
Sveiki, turiu Gaz 21 ir noriu paklausti ar galima pilti e85 kura su etanoliu? ar nebus per didelis oktaninis skaicius?
Pranešimai: 1909
Re: E85 kuras
Standartinė pofke78 »
paulius858 rašė:Sveiki, turiu Gaz 21 ir noriu paklausti ar galima pilti e85 kura su etanoliu? ar nebus per didelis oktaninis skaicius?
O koks E85 oktaninis skaičius? :?
jrjustys
Pranešimai: 752
Re: E85 kuras
Standartinė jrjustys »
Si tema tikrai buvo kalbeta. O isvada kiek pamenu: e85 degimo temperatura zenkliai aukstesne negu benzino, todel i variklius gamykliskai nepritaikytus pilti e85 kura, negalima. Is praktikos, tai pusbrolis i sovietini motobloka pila e85 ir vaziuoja, sake "trauka" geresne nei su benzinu.
868772848
paulius858
Pranešimai: 2
Re: E85 kuras
aciu uz informacija :)
Sergej
Pranešimai: 938
Re: E85 kuras
Standartinė Sergej »
uzpilk, ir pranesk ar pavyko uzvest.
Oktaninis e85 apie 103vnt ir variklis suvalgo jo apie 30% daugiau, tad be zikleriu pakeitimo net neturetu uzsivest.
e-85 normalus CRas butu apie 12-15vnt, o gaz21 du kart mazesnis (6.7-7.2).
isvada : nesamone.
xecutioner
Pranešimai: 329
Užsiregistravo: 13 Vas 2011, 19:47
Miestas: kaunas
Re: E85 kuras
Standartinė xecutioner »
uzvest gal kaip nors ir uzvesi bet... E85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such flexible-fuel vehicles (FFV) are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. There are a few major differences between FFVs and non-FFVs. One is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system. Another is that fuel pumps must be capable of operating with electrically conductive ethanol instead of non-conducting dielectric gasoline fuel. Fuel-injection control systems have a wider range of pulse widths to inject approximately 34% more fuel. Stainless steel fuel lines, sometimes lined with plastic, and stainless-steel fuel tanks in place of terne fuel tanks are used. In some cases, FFVs use acid-neutralizing motor oil. For vehicles with fuel-tank-mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used. kas angliskai bent kazkiek supranta visas straipsnis is wikipeadijos http://en.wikipedia.org/wiki/E85
kisa
Pranešimai: 336
Miestas: Vilnius/Jūrė
Re: E85 kuras
Standartinė kisa »
Šnekat, kad tik šnekėt, realiai nieko nebandę
Mašina ir užsives, ir važiuos, nekalbant, aišku, kad degimą be proto ankstint reik. o tai sukelia papildomą kaitimą, nors pats etanolis dega mažesnėj temperatūroj, nei kažkas anksčiau rašė, ir degimas jo šaltesnis...
Koba
Pranešimai: 86
Užsiregistravo: 22 Vas 2013, 21:59
Re: E85 kuras
Standartinė Koba »
Na bet vis tiek normaliai kažin ar dirbs. Šiaip kaip minėjo reikia žikliorius keist į didesnius ir tada reguliuot, nes etanoliui reikia daugiau oro sudegt. Na jis pigesnis, bet nepaisant to jis senam transportui žalingas, nes senesnėm ("naujoviškom") mašinom jo pilti net negalima. Šiaip dar galima skiest benziną juo, ko pasekoje nieko ir neatsitiks, aišku santyki reikia išlaikyti ne daugiau ant pusės.
laimiukas
Pranešimai: 33
Užsiregistravo: 21 Bal 2010, 11:30
Re: E85 kuras
Standartinė laimiukas »
Mano senike jawa net neuzsivede.teko pilt lauk.
martian
Pranešimai: 175
Miestas: Nemenčinė-Vilnius
Re: E85 kuras
Standartinė martian »
Koba -> Atvirksciai - E85tam reikia maziau oro sudegt. Esant stechiometriniam misiniui deguonies/benzino santykis 14.7:1 (deguonies kiekis, reikalingas visiskam degalo sudegimui), tuo tarpu deguonis/E85 9.7:1 ("riebesnis" degusis misinys, nei su benzinu).
Урал ИМЗ 8.103-10 1988 m.
Днепр ??? ????
Ford Fiesta Mk1 1982 m.
